What would cause two different users, using the same mfg file, to get two different ncl outputs?
I get:
$$-> CUTTER / 6.000000
SET / OFSETL, 55
ROTATE / BAXIS, ATANGL, -90.000000
SET / OFSETL, 57
ROTATE / BAXIS, ATANGL, 90.000000
SET / OFSETL, 54
ROTATE / BAXIS, ATANGL, 270.000000
He gets:
SET / OFSETL, 55
SET / OFSETL, 57
SET / OFSETL, 54
ROTATE / BAXIS, ATANGL, 450.000000
(Post takes care of overrotation)
Config setting, setting in machine, site, operation, nc sequence?
We are using a common workcenter in order to use the tooling for multiple jobs on the same machine. It just seemed to have changed about a week ago. I was troubleshooting and posting code when the rotation was suddenly wrong. PTC ncl files are notoriously wrong, but I have written pposts in IMS to clean it up, but when it changed the post no longer fixed the new state. I had another ME post ncl then run the post without changes and it works.
More thoughts...
Hello Scott,
the problem is probably in the Work Center definition.
There is the parameter named Rotation Direction which can have three values: Shortest, CLW and CCLW (see attached figure below).
And each of you specified different value, probably.
This could be reason why CL-output is different.
I hope that will help you.
Rostislav
More thoughts...
config.pro setting cl_rotate_sign_convention defaults to TABLE when it should be set to TOOL. All posts out good now.
