ModuleWorks generate std.out
C_Spagnolli
in manufacturing when I use the material removal simulation, a std.out file is generated in the working directory
It also does this using Creo Parametric with default settings, and it is not possible to delete it while the program is open.
I thinks in previous versions of Creo Parametric this file was not created.
Is this normal or are there any setups to fix?
Attachments file
Here's the pertinent contents of an article about this topic from 2021:
Applies To
  • Creo Parametric 1.0 to 8.0
Description
  • Can the location to create the log files such as std.out and std.err  be changed ?
  • Is it possible to change location for creation of log files such as std.out, std.err other from the "Start in" directory?
  • How to set different folder other than current working directory for creation of log files such as std.out,std.err?
Resolution
Applies To
Description
Resolution
