Pro/E used to have the option to use a part to subtract material from another. Does Creo 2.0 have this? I can't find it, or find anything on the web in this regard. I have a student that wants to make a matching thread in another part. This used to be easy, but now I can't figure it out!
Tim,
In Creo Parametric 2.0, try using the following:
You're done.
Dan Nordin
BAE Systems
www.baesystems.com
Tim,
You're done.
Dan Nordin
BAE Systems
www.baesystems.com
The concept is "merge". There are a few places to do this. Daniel has described a common method.
The idea is that you have to do this from assembly mode. Activate the part you want modified. The Boolean features are then enabled,
Daniel,
Thank you. Got stuck for a while, but your post most definitely helped. The group part threw me for a bit.
Thanks again,
Tim
