In Creo 3 i can create a "Stock Model" to get the remaining material after a NC Sequence.
How can i set it as Real stock for next sequences?
For example: first sequence is a Volume Roughing with a tool dia 20mm
I would like to create a new volume using the same mill window but limiting it to the remaining material of first sequence
I don't want to use Roughing and Re-Roughing 😄
I cannot replace the starting workpiece with his worked component of the familytable inside NC
I can save Stock Model as prt or stl, why i cannot use it for example for further operations?
Thanks a lot
Osvaldo
If I have well understood your problem, you should use one of the two sequences I surrounded below. From my point of view the trajectories that are calculated are not always very optimised but it's the only I have found to do what you describe.
Hi Raphael
thanks a lot for your answer.
Local machining is just a finishing sequence, i would like to reuse stock model in further roughin sequences.
For example i could work one piece and then rotate it on the 4th axis and working the remaining stock from another angle or using the remaining stock to worh on a 3 axis from a new operation.
I tried all but i thing it is not possible to do what i want (in this case STOCK MODEL is totally unusefull).
I could export stock model, create a new manufacturing, assemble the remaining stock as master stock and so on but is such a stupid thing 😄
Bye
Osvaldo
Hi Osvaldo,
As you say I also think this is not possible. In fact I don't really understand what is Stock model used for ?! In the company I work for, we only have 3 axis milling machine, and I sometimes have to be very imaginative to do the kind of things you describe.
The pictures seem to refer to a finishing sequence not to a roughing one.
Finishing do not need workpiece or stock model.
