I'm in the process of developing a thread milling process but I am not getting the correct tool path. I need a single pass tool path but I'm not able to find the right parameter combination to get single pass. I using a solid tool defined in Creo to simulate a multi-tooth cutter.
Rick
I think the thread milling tool is the problem. In PTC's infinite wisdom flutes are not flutes for a thread milling tool. Flutes are the number of thread profiles on the tool. Measure the lenght of profiles and divide by the pitch of the thread. Round to a whole number and put this in the "number of flutes" for the tool. This should change the number of turns the tool makes.
Ed
Rick
Ed
Ed, you nailed it! Thank you for your quick response.
