Prime gets this:
Maple Flow gets this:
Matlab gets this:
Julia:
Octave:
Wolfram:
Python:
The original solution as presented in the book MODERN ENGINEERING MATHEMATICS
Glyn James, Phil **bleep**, Sixth Edition
page 7
is as shown in screenshot. Its just a simple and direct solution on this.
Both answers are correct:
Thanks for spotting this, remember 7 mathematical programs get the complex result.
You can with some manipulation of the problem get 4.
The first step in the solution from the book gets 4.
It seems cube root gets 4 raising to the 1/3 power gets the complex result.
Very interesting learning thank you for spotting this.
Exactly that I think it is the problem with the mathematic softare. They cannot handle the swap of negative numbers when risen to 1/3 power, because those are not complex but simple numbers. (-4) ^ 1/3 is not a complex number as the negative sign swaps. They handle it correctly when i give it directly as 1/3 power but when i write this 1/3 power in a more complex way, they assume we have a complex number always as result
My original question is. I see two answers. One with complex number and one with simple number.
Doing simplifications i get the answer (4). A positive number.
The complex number is negative.
So, as it is just a presentation of a number, to my understanding, I will get a single answer. Otherwise, I will have to accept that every number has also a complex expression representing it. So, 4 = -2 -3.464i. I dont know much of mathematic theory if it is stands as logical, so please forgive me if I think it as not a logic answer.
If it is really accepted that each non imaginary number can have an expression as an imaginary number, then it is correct the answer to have two results. If it is not, then there is something that has to be corrected.
Mathcad gives as the answer the complex number only, when I write this number as given, as shown in first @terryhendicott 's screenshot.
Not Mathcad But Latex code:
\documentclass{article}
\usepackage{amsmath, amssymb}
\begin{document}
\section*{Rigorous Evaluation of $\left(-\frac{1}{8}\right)^{-2/3}$}
The expression involves a negative base raised to a rational power, which is multi-valued in the complex domain $\mathbb{C}$. We define the operation using the complex exponential and logarithm:
\[ f(z) = z^a = e^{a \log(z)} \]
\subsection*{1. Simplification of the Base}
First, we apply the negative exponent to find the reciprocal:
\[ \left( -\frac{1}{8} \right)^{-2/3} = \left[ \left( -\frac{1}{8} \right)^{-1} \right]^{2/3} = (-8)^{2/3} \]
\subsection*{2. Polar Representation of the Base}
The complex number $z = -8$ lies on the negative real axis. Its magnitude $r$ and argument $\theta$ are:
\[ |z| = 8, \quad \arg(z) = \pi + 2k\pi \quad \text{for } k \in \mathbb{Z} \]
Thus, in exponential form:
\[ -8 = 8e^{i(\pi + 2k\pi)} \]
\subsection*{3. Application of the Rational Exponent}
Substituting this into the power function:
\[ (-8)^{2/3} = \left( 8e^{i(\pi + 2k\pi)} \right)^{2/3} = 8^{2/3} \cdot e^{i\frac{2}{3}(\pi + 2k\pi)} \]
Since $8^{2/3} = (\sqrt[3]{8})^2 = 4$, the general solution is:
\[ w_k = 4e^{i\left( \frac{2\pi}{3} + \frac{4k\pi}{3} \right)} \]
\subsection*{4. The Three Distinct Roots}
For $n=3$ (the denominator of the exponent), there are exactly three unique values for $k = 0, 1, 2$:
\begin{itemize}
\item \textbf{Case $k=0$ (Principal Value):}
\[ w_0 = 4e^{i\frac{2\pi}{3}} = 4 \left( \cos \frac{2\pi}{3} + i \sin \frac{2\pi}{3} \right) = 4 \left( -\frac{1}{2} + i\frac{\sqrt{3}}{2} \right) = -2 + 2i\sqrt{3} \]
\item \textbf{Case $k=1$ (Real Root):}
\[ w_1 = 4e^{i\frac{6\pi}{3}} = 4e^{i2\pi} = 4(\cos 2\pi + i \sin 2\pi) = 4(1 + 0i) = 4 \]
\item \textbf{Case $k=2$ (Conjugate Root):}
\[ w_2 = 4e^{i\frac{10\pi}{3}} = 4 \left( \cos \frac{4\pi}{3} + i \sin \frac{4\pi}{3} \right) = 4 \left( -\frac{1}{2} - i\frac{\sqrt{3}}{2} \right) = -2 - 2i\sqrt{3} \]
\end{itemize}
\subsection*{Conclusion}
The "two answers" usually cited are the **Real Root ($4$)** used in elementary algebra and the **Principal Value ($-2 + 2i\sqrt{3}$)** used by computational engines like WolframAlpha.
\end{document}
