Beginner Programming Doubt
ejanssen
Hi !,
I trying to learn the programming methods at mathcad, for that I'm triyng to make a loop to classificate a Pressure Vessel according to the fluid,Pressure, Volume. But i cant get it, if any one could help me with that.
I think he correctly handled that by defining "l" which removes the units from L.
The problem I think was the use of "while" in the second program.  It should really be another "if" statement.  See attached.
Alternatively, I would recommend the use of a matrix "lookup" function.  I think that might provide a more concise solution.
13 REPLIES 13
MikeArmstrong
(To:ejanssen)
How about the attached?
You were comparing L which had the units of energy to the values in your program.
Mike
ejanssen
(To:MJG)
Mark, that was exactly what i need, thanks for your quick help !
MJG
18-Opal
18-Opal
(To:MJG)
Also, consider multiplying the limits of L by the intended unit.  This will allow you to define L in any units, and Mathcad will do the proper conversion while classifying your fluid.
MikeArmstrong
(To:MJG)
This would have been my way of setting it up.
ejanssen
(To:MJG)
Can you show me an example of this oder way to do it ? It is always good to know more than one method.
MJG
18-Opal
18-Opal
(To:ejanssen)
Here is what I meant by my comment on the units.
You'd want to set up the second program similarly.
Regarding my comment about setting this up as a matrix lookup function - I'd have to play with it since I don't typically do those.  Not sure I have the time right now.
MJG
18-Opal
18-Opal
(To:MJG)
Curiosity got the better of me.  Here is how to approach this with a vlookup function.
Hi Mike,
Thanks for the quick reply, in your example the "Grupo" is not the correct it shoud show "Grupo 5" for a L<1.
Also i want to classificate the Category, that is a function of the Grupo and the Fluid ( A or C)test.png
MikeArmstrong
(To:ejanssen)
That's because I divided L by kN*m. It works if you divide L by MPa*m^3.
Mike
StuartBruff
(To:ejanssen)
Emilio Janssen wrote:
Hi !,
Noting that you had made the argument to Grupo dimensionless, does the attached do the kind of thing you want?
Stuart
Hi !,
I had a few spare minutes, so I tidied the worksheet up a bit and handled L with units:
Stuart
Thanks Stuart, very usefull those examples and methods !!
