Blue area of the Menue-Bar
vlehner
maybe somebody has the same unpleasant and disturbing problem while using MCP 4:
When often switching from Mathcad to another program, the blue area of the menue bar gets thicker and thicker.
I wonder why software developers make such a crap.
Volker
(To:vlehner)
I have no clue, and it does not happen in my situation.... at least, not with a few switches (ALT-TAB). How fast does you bar grow?
Does it also happen when Prime is not maximized (using the full screen)?
What OS (Windows 7, 8 or 10)?
vlehner
(To:LucMeekes)
I have Windows 10 and it doesn't happen when Prime is not maximized.
about 20-30 switches to the size above to see in my post
Volker
Volker
VladimirN
24-Ruby II
(To:vlehner)
Volker,
Please send your issue to PTC's tech support by using "Mathcad Support Center" (you can do it, even if you use Express version of  Mathcad Prime):
http://blogs.ptc.com/2011/09/22/how-to-use-the-brand-new-online-mathcad-support-center/
