Hi guys I am still learning the ptc mathcad software.
I am trying to use trial and error to find the solution of depth (Y) in open channels using mathcad solver block.
I have set all guess values and constraints, how best can I solve this?
Or is there another way of determining the value of Y.
I have also attached the original question with step by step calculations and correct answers, in case one needs to restart everything.
I appreciate your input and comments.
Thank you in advance.
Hi Fred,
Thank you very much for the step by step calculations you provided.
Gchega
