Can I define an expression as a single value?
kwadley
In the highlighted equation, I am attempting to define an expression with a single value.
Is this possible or should I first solve for 'Kg' as all other variable are defined?
Other tips on the best way to do this?
TIA,
Kevin
MikeArmstrong
(To:kwadley)
If you have all the other variables it should be relatively easy to solve for K.s.
You could put both equations into a solve block and solve that way.
Mike
(To:kwadley)
You mean like this?
Yes, that's possible.
