Can Mathcad Import/Export from these softwares?
rubenvillarreal
I would like to import an entire worksheet from MAPLE or MATLAB. Is it possible? How should I do that?
Also, I would like to export the code for those software as well.
Thank you!
You cannot import or export Maple or Matlab code. Depending on the version of Mathcad you have you can possibly link to them and pass information back and forth, but that is all.
By help HTML?
You're talking about regular Mathcad (14/15) or Mathcad Prime?
For regular Mathcad version (quote from "Mathcad Help", F1 hotkey): "in addition to importing and exporting MATLAB data files using the File Input, File Output, or Data Table components, you can also use the MATLAB component to execute MATLAB scripts using data from your Mathcad worksheet, and return the results to Mathcad".
Thanks all for their replies, all valid answers from different perspectives.
