Check results with different colors
TikkaMasala
11-Garnet
Hi
Is it possible to have results to change color depending on the resulting value?
As attached is a sheet describing the question.
Thanks for help.
It can be done using a text-box scripted item - see attached.
Alan
RichardJ
(To:TikkaMasala)
Here are a couple of controls that are a bit more versatile than the one Alan posted. The first one is based on an MSForms 2.0 textbox, the second on a Mathsoft textbox.
