Creating a program function ? (II)
lvl107
20-Turquoise
  Hello, Everyone.
   Creat a program function RLL(  ) ?
           Thanks in advance for your time and help.
                 Regards.
Message was edited by: Loi Le
24-Ruby V
(To:lvl107)
You may use an "unravel" program to use Freds routine:
Or how about this:
7 REPLIES 7
ppal
17-Peridot
(To:lvl107)
What is the question?
lvl107
20-Turquoise
(To:ppal)
   I'm sorry because my question is not clear, Mathcad User.
   I guess Werner who did help me answer some my questions in some previous posts, but the last question I need help is :
   The question is "Create the program function F(  ) ?
          Best Regards.
Fred_Kohlhepp
23-Emerald I
(To:lvl107)
lvl107
20-Turquoise
(To:Fred_Kohlhepp)
   Many thanks for your time and help, Fred.
   Could we edit the program F(  ) ?
         Best Regards.
Fred_Kohlhepp
23-Emerald I
(To:lvl107)
The function "str2num" converts letters to ASCII numbers.  The function "num2str" converts ASCII to letters.  Those will work inside F().
F() as written, works on a vector, not an array.  Select either a row or column.
24-Ruby V
(To:lvl107)
Or how about this:
lvl107
20-Turquoise
   Thanks for your time and help, Werner.
         Best Regards.
