I have run into an error using the solve block function in MathCAD 15. I have a function that I want to input a range a variable into. I can use the solve block if I only enter in one value. I get strange results when I try to enter in a range of values for the solve block to solve. Do you have any recommendations to fix my problem?
You can't use a solve block like that. You have to turn the solve block into a function and then call the function multiple times.
try changing the equation for p1(theta1) from a global definition to a function definition. Rather than three horizontal bars, a colon equal ("shift :" in Mathcad.
