Good day. I was wondering if anyone can introduce a good tutorial and help me on how I can compile the global stiffness of this example problem in mathcad prime. I am currently studying FEA Method and still do not know how to properly mesh 2d into a single matrix. I hope anyone can help me program it. Thank you.
Hi Teddy
Errata for reference https://sharif.edu/~ghaemian/Finite-Element_files/File/chapter3.pdf that gives erroneous results.
Make three small changes and it works
1> Add minus to k2 in column 0
2> Add minus to k5 in column 0
3> For k3 first term divisor is S not 3.
If you happen to have access to Mathcad v15 and you have the mechanical engineering e-books, there is a book about FEA - "Finite Elements Beginnings". All the examples you will need are contained in that book.
Here is one way
But it is not giving the correct answer so looking at it
Hi Teddy,
Happy it is now working with a third attempt at elemental stiffness matrix.
Hi Teddy
