Function Variable with Condition Statement
rjaison
Hi
I couldn't understand why the function with condition statement in this case IF statement as shown below dose not work properly
Is this right way ? or I am making some mistake.
BR,
J.Randeep
Here's a workaround in M15:
Alan.
P:S
On the other hand if i just use Maximize or Minimize manually according to the condition with out any condition statement it works correctly
I think it is a bug in Mathcad 15. In Prime OK:
Hi
Thanks for your insight.
Unfortunately I am using Math CAD 15 I need to find a solution that works with it.
If you are certain it is a bug, Math CAD support team should be notified about this?
J.Randeep
J.Randeep
It is not a bug. It is one methodology of the soft.
If(a=b, m, kg) - a bug in Mathcad 15 but not in Prime.
Can you use in your case y(x) or -y(x) for the finding min or max?
Alan.
Yes it did work.
But the logic is quite complex, it should be simple as Valery was mention it works fine in Math CAD Prime.
Thanks for your help.
J.Randeep
