I want to see the values of f(n) by using the find command.
But i am getting the error as variable is undefined.
Please help me.
Thanks in advance
You need to make sure you have an initial guess for n, and make the solve block a function of vk - see attached.
However, as Fred points out, it is easy to solve explicitly for n here.
Alan
Not sure why the solve block won't work. (Doesn't like v_k as a range variable but it wouldn't work for a single value either.)
But you can use the symbolic engine to get n as a function of E_k and v_k, see attached.
By the way, what's g_k for,decoration?
Alan
