Goodness of fit Tests using pearson system
mali-2
How can i calculate critical values of Goodness of fit Tests for Weibull Distribution using pearson system
(To:mali-2)
mali-2
(To:LucMeekes)
It likes good, but my problem is "when i know the type of distribution of the test statistic say "Kolomogorov Sminrov test statistic " and estimate parameters, critical values can be yielded via the probability density function or the cumulative function of the pearson type?
VladimirN
24-Ruby II
(To:mali-2)
Please check the following discussion: Kolmogorov-Smirnov test
