Help Search Button
DuanSerfontein
Help Search Button
I am Using mathcad 15 in a Windows 7 OS. My search button under "help" doesn't give the option to search for a function or anything, it only provides me with the letters of the alphabet. should it be like this? if not please help, I have tried to repair mathcad but it didn't seem to work.... PLease HelpUntitled.png
12 REPLIES 12
I have never seen that before. Have you tried the index tab?
Mike
http://communities.ptc.com/servlet/JiveServlet/showImage/2-149416-2532/bar_anim.gif
Hi
Thanks for your reply, Yes I have and it looks the same. Is there some way i can get hold of the help folder's content?
You could try repairing your installation.
Mike
Duan Serfontein wrote:
... Is there some way i can get hold of the help folder's content?
You can find the individual files at: C:\Program Files (x86)\Mathcad\Mathcad 15\doc\HELP_EN\Help (I guess you ignore the (x86) if you have a 32-bit machine - and I've no idea where they'll be if you're on a network), but your Search facility shouldn't look like it does! Have you tried repairing the installation like Mike suggested?
Alan
Hi
Yes I have tried repairing the installation but it didn't work, I think it's something that I installed or need to install but i can't think of eneything except for an anti spyware or some java apps.
Duan
I could send you a copy of my help folder - if that's allowed.
Mike
Hi
Please maby it will help, and I have a legal copy so i can't see why not?
I have attached a copy of my help files. Be sure to back all your files up before making any changes.
Mike
Solved the problem PTC phoned me and after a long chat with the people we decided that if you open help it gives you a URL directory cope that adress and paste it into your inter browser...
Hello!
You need to use Mathcad help within the program ("Mathcad Help" key F1), rather than calling it through Internet Explorer.
Thank you... but as you can see from the first post my help doesn't work, and don't say that I should try and re install it because I did that a hundred times..
so if there's people out there with the same problem a solution is to use your inter browser to open the help URL...
Well, if "Mathcad Help" does not work in the program itself, in this case, it is necessary to contact with technical support PTC, creating a new case, here: http://www.ptc.com/appserver/cs/case/case_logger.jsp
P.S. I think that in this case a problem with Windows 7. As an alternative solution - to use the installation CD with Windows 7, run the installation of the system and then select update (but not a full installation of the replacement of the current system).
