Why does the first function of "X.bolt.w" not compute, but if I remove the end values of n.b.row.h*29, it works - as shown in the second function. It doesnt make any sense.
I'm surprised the second one worked!! You should probably use something like the syntax as shown in the attached - it's much simpler!
Alan
Firstly you can't define your programs loops like that. Look in the help menu for tips on this.
It also looks like you haven't defined x.s in your worksheet.
Mike
My bad, I took this out of a larger file. I updated and re-attached
Look at how the first definition of X.bolt.w does not work, but then the second definition works fine. All I did to the first is as another row at the end, exactly like the others.
Alan
Interesting, I dont know why I didnt think the range variable recognized number patterns...that's awesome!
Thanks everyone for the help, as you can see I am not a mathcad expert.
It seems to be a rather arbitrary limit on how many entries you can have in the list for a for loop. it works OK in version 11, but not 13, so I guess it was introduced when the rewrote the compute engine in 12. To get around it, put the list in a vector (which, IMHO, would be better style anyway). Or, as Alan suggests, don't use a list at all.
James,
I assume you are trying to determing the x and y corrd of each bolt, eventually to calculate an eccentrically loaded bolt group?
Anyway, attached is a more general function to do this.
Wayne
