HHHH
9-Granite
Help
Appreciate if you help to fix the error in the attached sheet
Thanks in advanced
Enclosed is latest sheet version 2.
On the right you have images taken from a Mathcad 15 or earlier worksheet.
Why don't you use the XMCD,MCDX Converter found on the Prime Ribbon at Input/Output to convert the original file to Prime?
Enclosed sheet.
I have put in the indices used in the original worksheet.
I have corrected a formula.
Still a problem with two equations but I will work with them some more.
Really I'm so grateful sir, I'm waiting for your nice work
Thank you so much really you solved the puzzle and broke the knot 😍
фаил не открывается 😠
