How can I have Celcius not Kelvin on the X-axes of Prime plot
ValeryOchkov
24-Ruby IV
Help please - see the attach
Oviously it does not work the way it should (by simply chosing °C in the unit box) so one crude way is to do the conversion manually. Not very satisfying, I guess.
17 REPLIES 17
Thanks, Werner!
Same bag:
The Kelvin and Rankine scales are absolute--they both start at absolute zero and are therefore a ratio.  Centigrade (Celsius) and Fahrenheit scales have arbitrary (and different) zero reference points.  Mathcad has to use functions for that conversion.  If you look under units the the ribbon, you can select which units to plot with.
Not all is fine in Mathcad 15 too
Hi Fred!
Think we found a bug in Prime 5!
What you show was exactly what I tried first (and Valery sure did so, too) and it failed because we both used Prime 5.
It works OK in Prime 4 but throws an error in Prime 5!
So the bug was freshly introduced with Prime 5 (and we thought there would be no development of Prime any more 😉
ttokoro
Maple has:
  1. Fahrenheit
  2. Celsius
  3. centigrade
  4. Reaumur
  5. Rankine
  6. Kelvin
But the 7 not the 6 is a fine number! Do you know 7-th temperature scale? I Know!
First please explain the difference between 'Celsius' and 'centigrade' .
I agree:
From WIKIPEDIA:
Before being renamed to honor Anders Celsius in 1948, the unit was called centigrade, from the Latin centum, which means 100, and gradus, which means steps.
@Fred_Kohlhepp wrote:
I agree:
From WIKIPEDIA:
sorry - not so simple
So, with that settled (Thanks! Fred),
the 6th through 8th temperature scales, or units, could be Delisle, Newton and Romer;
per https://en.wikipedia.org/wiki/Conversion_of_units_of_temperature#Comparison_of_temperature_scales
Of these, Delisle is interesting because it goes hotter for lower values...
One interesting Mathcad Web-sheet:
The International Temperature Scale of 1990 (ITS-90)
(To:ttokoro)
@ttokoro
Valery needs/wants  °C on the abscissa!
ttokoro
I understand what is the problem. X-axes allows K or R and not degree C or degree F. (x=x*unit ,not x=x*unit+C*unit)
So x axes can use the unit of delta degree C.
But Prime 4 (Expresseven) allows deg C on the x axis as well
And the beat goes on . . . .
I guess with the new fancy graphing utility the built-in graphs could be farmed out to the interns.
At least this new plot add-in can't show the bug in question here as it is totally unit-unaware. Hurray!
