I'm learning my way around Mathcad and I can find any examples of how to get multiple out puts from a program in Mathcad.
For example, I need to get Vh,Vc and Vt1 as outputs for a graph from this program. Any suggestions?
Ken
You're over-complicating it. Write each function out seperately then define a vector function that gives all three answers.
Send please Mathcad Prime file
Make your return a variable matrix. Example:
or:
Good point, Fred. I didn't bother to look very closely at Ken's original equation.
Thank you very much Fred. That was a much better way to do it. I've go a lot to learn about Mathcad and how to think about it.
Thanks again,
Ken
