I made a separate Math CAD sheet where I have wrote a function
Now I am trying to insert this sheet into my main calculation sheet as Insert--------> Reference
So that I can recall that function
But it is not working.
Any ideas!
BR,
J.Randeep
PS I have attached the sheet which I am trying to use as my reference sheet
Hello Randeep,
actually it is quite easy.
You're done. The target sheet calls up the source sheet function and all variables on it.
Raiko
