How to animate experimental data
naz_or
i would like to animate experimental data; how is that possible with Mathcad14? It is simple (x,y) pairs that should be plotted on graph during "time".
Best regards,
nazor
16 REPLIES 16
RichardJ
(To:naz_or)
There is a long thread on that:
http://collab.mathsoft.com/read?51325,11e#51325
Richard
>I would like to animate experimental data<<br> _________________________
Any help in there ?
jmG
Problem solved. Thanks jmG!
Best regards,
nazor
naz_or
(To:naz_or)
Hi there,
I solved the problem. I know how to animate data, but there is limitation of number of frames that can be used in mathcad 14. Max number of frames is 999; is there any possibility to extend the number of frames?
On 7/25/2009 4:36:31 AM, naz_or wrote:
>Hi there,
>number of frames?
FRAME from -999 to 999
But we have an error in Mathcad 14 at negative values of FRAME.
In Mathcad 11 all is ok!
FRAME from -9999 to 9999
Val
http://twt.mpei.ac.ru/ochkov/v_ochkov.htm
>Hi there,
>number of frames?
_______________________________
If you are not trying to animate cartoons, 999 frames is a lot ! If your data set is longer than 999, you can decimate ... starting by taking every 2 . How long is your data set ? Decimation will go by integer numbers and that might not be convenient either. In that case you could spline the data set and resample as you wish. Not seeing your data set, you will get suggestions, only.
jmG
Well, I want to animate (make a movie) changing of Epot with distance. The number of (x,y) pairs is 1500, and the maximum that can be animated is 999. I'm posting data also. Any help would be useful.
Best regards,
nazor
naz_or
(To:naz_or)
sorry for double upload of same files!
RichardJ
(To:naz_or)
Why not just add two points every frame? Unless your movie is going to be very slow and very long you would not even notice the difference compared to adding one point every frame.
Richard
>Best regards,
>nazor
Can be so:
Vyacheslav Tarasov.
suggestions was very helpful. I know that i can reduce number of points, but i wanted to override problem with limited number of frames. Post by Vyacheslav Tarasov was very useful. Problem solved!
All the best,
nazor
>...i wanted to override problem with limited number of frames<<br> __________________________
In my work sheet, set n:=2*FRAME,
in the video, set RFAMES 7499.
You will see the entire scan.
No information is missing on playback.
jmG
On 7/25/2009 7:25:42 PM, jmG wrote:
>>...i wanted to override problem with limited number of frames<<br> >__________________________
>n:=2*FRAME,
>playback.
>jmG
Erratum:
>in the video, set FRAMES 749.
>Best regards,
>nazor
Your data set, if decimated, does produce so much a different trace that it is time to wonder about the collection. Judge by yourself, enable/disable the decimated X, Y, Z. Knowing nothing about unknown does not help the originator, neither the collabs.
Your work sheet is restricted to Mathcad versions above 11. This work sheet is version 11. Hope it helps about the mystics of the data set.
jmG
PhilipOakley
(To:ptc-1368288)
Google for AVIsplitter. It also has an AVIjoiner in
the suite. That would allow you to do it in parts.
Philip Oakley
Best regards,
nazor
Better late than never:
