How to create a vector B that has only the values of vector A that are lower than a value?
DrilonShabani
8-Gravel
If i have a vector A=(0.45, 1.78, 0.82, 0.95, 1.99,  1.12, 0.77), how to create a vector B that contains only B=(0.45, 0.82,  0.95, 0.77); only values that are lower than 1. The other values may be 0 for example.
(To:DrilonShabani)
Like this:
15 REPLIES 15
Really?
(To:DrilonShabani)
Like this:
But is number 3 in this case considered as the second number or third number of the matrix? Because the output of the matrix must be with the same number of elements. I need them to be connected with some other vectors.
(To:DrilonShabani)
"3" is the second number in the vector.
Your example shows a vector B that is shorter than A. That's what my  (and Fred's) function provides.
Please specify more carefully and exactly what you want.
Is it possible that i get a text instead of a number?  For example: "Not applicable"
Sorry for my amateur question.  😕
(To:DrilonShabani)
What is your criterion for 'Not applicable'.?
If any value is bigger than 1 in vector A, i want the result on vector B for that number to be "Not Applicable"
Like this?
Exactly . Thank you very much to you,  LucMeekes and Fred.
MJG
18-Opal
18-Opal
(To:MJG)
Here's another approach:
I have one more problem. Lets say i have vector B that you created and vector C=(4,  9, 19, 2, 11, 19, 55). I need to create vector D that is: if the value in B is NaN,  also D to be NaN,  if the value in B is number(lower than 1 in this case),  the result in D must be the value from C.
24-Ruby V
(To:MJG)
You may also use
D:=IF(A<1, C,NaN) (vectorized, of course)
so you would not need to calculate B first.
If 0 is OK (instead of NaN or "n.a.") you may simply use this vectorized statement:
In Prime . . . You could just use the lookup function...... like this . . . much simpler
