How to make headings in Mathcad
adeters
How do I make headings in Mathcad like I do in word?
StuartBruff
(To:adeters)
adeters wrote:
In Word, you can highlight the headings and format them all to be the same. I would like to format all headings the same, and all equations the same to link similar contents. Is this only possible by highlighting each heading and changing the format individually?
10 REPLIES 10
Prime or 15?
Mathcad 15
May be so?
StuartBruff
(To:adeters)
Which version of Mathcad are you using?
What do you mean by "Headings like in Word"?  For example:
Do you just want to be able to create heading with different styles (eg, a larger font and bold text)? That should be straightforward in either version, but easier in Mathcad 15, as you can create your own styles (or use the built-in ones).
Or do you want to autonumber headings? ... if so, you're out of luck, unless you're using Mathcad 15 (or less) and willing to use a slightly unorthodox method.
Stuart
I am interested in formatting headings not headers
Sorry, Ai nou Inglish very plokho!
StuartBruff
(To:adeters)
That is exactly what I was looking for! Thank you!!
Good day Anellise and welcome to PTC Community.
I am glad you found your answer; there is a wealth of knowledge here.
If Stuart's answer fixed your issue, would you please mark it as correct?  This way the answer bubbles up to the top of this discussion and makes the solution easy for others to find.
Best,
Toby
