To organize my Mathcad prime 3.1 solutions, I need to get the filename as a string inside the worksheet itself. How can I get this?
There is a built-in variable CWD which contains the current working directory as a string, but unfortunately there is no variable containing the filename,
As we don't have scripted components in Prime like we are used from Mathcad (15 and below), I guess you are out of luck.
I have searched this function in help. But Werner is the best help
I'm not sure there's a direct way in Prime 3.1 (there is in M15 using components). It may be that you have write a function using the Mathcad Prime API (or get someone to do it for you ... I don't know anything about external comms with Mathcad Prime, but I suspect you'll need C or C++ to make a standalone function that you can then call from within Mathcad)..
Stuart
Interesting. I have written some external C# Applications to communicate with prime3.1. That works well but I have no idea how to extend prime with functions.
Anyone there who can give me a hint?
Look in the help: there is a chapter "Custom Functions" that describes how to create your own function using C.
