I'm developing 2d frame stiffness analysis.. im on the the final stage.. how to solve "This value must be an interger".. this will appear when i try to input the member force to excel component.
i is a range variable, so you can display memf(i)[1, but if you want to assign the results to a variable then the inedexing must also appear on the LHS of the assignment. So X:=memf(i)[i will give you the same error, but X[i:-memf(i)[1 will create a vector, X, that contains the results. I don't think there's any way to do that directly in the Excel component (but I'm doing something in Excel right now that prevents me from trying it, so I am not sure of that), so you will have to create vectors that contain the desired results, and then use those vectors in the Excel component.
Following Richard's suggestion:
Thank you so much...
What is the local definition of "I" just after the error?
Thank you sir.. That's my problem..i don't redefine the i.. Thank you again sir.
Thank you sir..
