please help to solve the problem for inserting pic to workshop sheet
It looks as though you're dealing with TWO pictures, rather than a single picture.
The top part of the image you provide shows a table on NCV8401 and NCV8401A on the left side and a table on IPD50N04SL-08 on the right side, while the bottom part of your image shows the SAME table on NCV8401 and NCV8401A on both the left AND the right side, although the right side is smaller in size.
Are you sure you didn't (inadvertently) copy pictures on top of each other?
