Labels in bar chart - Mathcad 15
ochristensen
Hi
Is it possible to put "labels" below bars in a bar chart, to indicate what they represent? I believe I stumpled upon some kind of workaround some time ago, but I'm not able to find it again.
Thanks in advance
7 REPLIES 7
I do it manual
Then I'd rather put the data in Excel and make the chart there.
If you download and install this ebook: Creating Amazing Images with Mathcad 14‌, there are functions that will add text to a graph.
Thanks for the link Richard. I've tried to implement it, but haven't been able to make it work. Don't know if it has something to do with the function using c and this being predefined as the speed of light. It's not a problem in the ebook, but seems maybe to be the problem, when I try to use it in my own project.
That maybe a problem, but without seeing the worksheet it's impossible to say for sure. Try doing a find and replace, and replace c with cc in all the applicable functions.
Please provide your worksheet with this problem.
We can insert Excel-sheet in Mathcad
