I am new to PTC / Mathcad V15.0 but am trying to use this great tool effeciently. For my job I have solved a problem which involves 8 equations and 8 unknowns. I have successfully arranged my equations to arrive at the correct solve block answers using the command Find as shown below:
The output naturally provides numeric (in this case...complex) solutions. Here is where I need help. With the results I need to conduct additional calculations but it does not seem that Mathcad does not recognize the value of each variable...such as K11 = 0.21675 + 0.19125i. Must I define these variables manually after the solve block or is there a command which will link the output to its respective variable. I plan on using the 8Eqnt/8Ukn solve block to solve for different givens...however, this currently means I need to manually set the correct result for each of the 8 solved variables such as K11:= 0.21675 + 0.19125i.
I appreciate any recommendations.
Thank you.
Jim
Hi Jim,
We need the relative worksheet so that we can give you some advice.
This document was generated from the following discussion: Link results from Solve Block output for subsequent calculations.
How about this?
