I want to create a table that has labels across the top row and labels down the left column. It seems that a regular Mathcad table will not allow this because it thinks my labels in the left column are undefined variables. I would like to use an Exel component for the table, but the table prints kind of fuzzy. Is there a way to get a higher resolution Excel component? Or just a better way in general to enter such a table? Thanks
Without using Excel, you can do simethin like the attached
Thanks for your document Wayne. How did you display it as a table with borders? Is that still possible with Prime 2.0?
I don't have Prime 2 right no, but in M15
select the matrix, the Format>Result>Display Options>Matrix display styl
to get rid of (or show) the automaitc column and row headings, right click on the talbe and slelct properties from the drop down menu.
Great. Thanks a lot.
Erica Rendon wrote:
...as a table with borders? Is that still possible with Prime 2.0?
No. In Mathcad Prime 2.0 results can not be displayed in tabular form. The result is organized as a matrix. Converted document for Prime 2.0 attached to the message.
Thanks Vladimir.
You're welcome.
