Morning,
I'm also experiencing MathCAD Greek Symbols issues.
I can't understand why this has occured. I have reinstalled MathCAD 14 twice and installed all fonts, but to no effect.
This is becoming an urgent problem as it is is stopping work from being approved.
Please can someone assist?
Ben
In the end the problem was to do with my graphics driver not allowing the symbols fonts to install. This was on a Dell M4400 precision laptop with a NVidia FX770 graphics card. I updated the driver and everything then worked.
James, thank you for your very quick reply.
So, shall I attempt to reinstall MathCAD again and then update the graphic driver or just update the drivers?
Do I need to install the mathcad fonts again??
Ben
Why don't you try doing the easier of the two.
I would personally try the driver.
Mike
When you reinstalled symbol.ttf how did you do it? Did Windows say anything when you installed it? It is possible to think you have reinstalled the font without actually doing so. If you did not delete symbol.ttf from the fonts folder before installing it again then Windows can try to outsmart you. It decides that since symbol.ttf is already installed it doesn't have to do anything! If the font installed correctly then Windows will have given you a message to that effect.
