Mathcad Prime crashes when I use absolute or Determinant function in IF statement
avarma
Hello All,
My requirement is simple I want to compare two numbers and I want the maximum value in return irrespective of its sign. This is how I tried in Excel if (abs(A)>abs(b),A,B) and it worked well.
I tried the same function in Prime3.1 and it crashes every single time I used it. One more thing what I've observed is, the IF statement is working fine when I haven't used Abs function or Determinant operator  in it. The real problem arrives only when I include Abs function in it.
Someone could please help me in resolving this issue.
Thanks in advance.
Ashok
12 REPLIES 12
StuartBruff
(To:avarma)
Ashok Varma wrote:
Hello All,
Thanks in advance.
Ashok
Could you please post a worksheet with an example of it crashing?  I don't seem to be having the same problem. Thanks,
Stuart
VladimirN
24-Ruby II
(To:avarma)
Try to turn off "Multithreading" option:
1. Go to "Calculation" tab --> "Calculation Options" button.
2. Click on the "Multithreading" button.
StuartBruff
(To:VladimirN)
Well, turning it on crashed my Prime 3.1 after clicking Calculate a few times.  The worksheet raised an mpl% exception error for f(-1,-3), the first couple of times, then threw its teddy bears out of the cot the third time.   Unfortunately, whatever was going on prevented me from getting a screen shot using the PrtSc key on my Win 10 PC.
Stuart
You use Win x86 or x64-bit OS?
StuartBruff
(To:VladimirN)
Windows 10 Pro
Processor: Intel Core i7-2670QM CPU @2.2 GHz
Installed RAM: 8.00 GB
System Type: 64-bit OS, x64-based processor
It seems that this option crashes the 64-bit version of the program.
StuartBruff
(To:VladimirN)
Typical.  Why me?
Stuart
Скажити мне, пожалуйста, Владимир. Кто русской эквивалент "Мерфи" - невидимый человек, который гарантирует, что "если что-то может пойти не так, это будет"?
StuartBruff wrote:
Typical.  Why me?
Because you're too smart for a regular user of the program .
Stuart,
Could you give an example of an English-speaking environment, to make it more clear what you mean?
StuartBruff
(To:VladimirN)
VladimirN. wrote:
StuartBruff wrote:
Typical.  Why me?
Stuart,
It's OK, Vladimir.. I found it: Murphy is Мерфи pa Russki.
Stuart
http://murphy-law.net.ru/
Yeah I turned off Multithreading and still it was crashing and I'm using 64 bit version. I could able to take the snap shot off error and attached those pictures here. What would be the solution for it now .
StuartBruff
(To:avarma)
You could try something along the lines of replacing the |expr A| >= |expr B| by a function that carries out magnitude comparison by a different means.  For example,
Stuart
VladimirN
24-Ruby II
(To:avarma)
And have you tried reinstalling the program?
