Prime Users,
Does Mathcad Prime has a built-in function to find the squareroot of a matrix?
I do not see one with my M14.
Thanks...
Here's a very handy function that Alvaro posted some time ago. It allows you to apply any function to a matrix. In this case, the downside compared to the solve block approach is that you can't find different roots by changing the guess values.
I see only 2 new built-in tools for an array in Mathcad Prime:
- return a row of a matrix
- return a norm of a vector/matrix
Sorry I think you must create/search an user tools for your task (A=S^2 - it is not a square root of the each element of A - see the attach) in Mathcad 14/15 and Mathcad Prime!
Raj sharma wrote:
Prime Users,
Thanks...
Depends what sort of square root you mean - see attached.
Alan
Sorry,
but a matrix 2x2 is not a problem.
A problem is a matrix 3x3 and more.
Valery Ochkov wrote:
Sorry,
Yes, I just used the 2x2 as an example. See attached (in M11 format - though generated in M15) for more general n'th root of matrix function. It includes a 3x3 example!
Alan
Very elegant!
Alan
Can it be used with the vector sum function?
Mike
Here's a very handy function that Alvaro posted some time ago. It allows you to apply any most functions to a matrix.
What would you expect a vector sum of a matrix to be?
Here's a very handy function that Alvaro posted some time ago. It allows you to apply any most functions to a matrix.What would you expect a vector sum of a matrix to be?
Matrix sum ![]()
Mike
Thanks Alan, Richard and all..
I like the method using eigenvecs and eigenvals functions..
And what about cholesky(M)?
Only works for symmetric matrices.
Alan
Alvaro function gives wrong result in symbolic case because of symbolic bug.
To exclude this bug it`s necessary to use eigenvec() function instead of eigenvecs() to right mapping of eigenvalues and their corresponding eigenvectors
