Need help in using Mathcad
klian
A sequence Ln is such that L1 = 0.2, L2 = 0.1 and
Ln = 2Ln-1 - 1.5Ln-2      ( n >= 3 )
Use Mathcad to determine the value of L43, giving your answer to 2 decimal places.
Need help to input this into Mathcad as i am new to this software... Thxs...
This is under which tutorial in Mathcad?
StuartBruff
(To:klian)
You will need to look for help about "range variables", plus basic expression entry and editing.  Here's an example of how to create a similar sequence
Stuart
StuartBruff
(To:klian)
Stuart
24-Ruby V
(To:klian)
Maybe you'd like zo create a function to get the n-th element of the series.
As you can see, the most obvious implementation (recursion) also is the most inefficient one.
