Nonlinear optimization (derivative free) in Mathcad?
KGMEurope
Hi All,
Could someone tell me if there's a spreadsheet available, or any solution with built in functions to perform a Nelder-Mead simplex optimization of multi-variable function?
Zsolt
RichardJ
(To:KGMEurope)
There is no built-in function, but why do you want to use this algorithm? Because it doesn't require derivatives, or for some other reason?
I have an expression like: G(y,x,c,v,b,n)
The expression between variables and G is not closed form, it's self-written function.
I want to find the closest point of G=0 surface to the origo.
RichardJ
(To:KGMEurope)
Look up "minerr" in the help. It should do what you want. If you can't get it working post a worksheet with your problem (to do so, click on "Use Advanced editor" at the top right of the edit dialog).
Minerr requires "n" equations for "n" variables, while I'm having only one equation.
RichardJ
(To:KGMEurope)
I'm not sure where you read that, because minerr does not require n equations for n variables.
Can you post a worksheet with a better description of the problem?
