One minimize problem - numerical and symbolical solutions
ValeryOchkov
24-Ruby IV
I am trieing to solve one minimize problem.
Numerical is OK - see please the picture and the Mathcad 15 sheet in attach.
But numerical - problems - see please two sheets (15 and Prime 3.1) in attach.
Any help please.
The problem of the race (from point 1 to point 4) on the lawn, plowing and asphalt
or
A a ray of light in a three-layer plate
23 REPLIES 23
Ждем-с! I am waiting for the solution!
A try in Maple
Hi Valery.
What Maple is telling is that the critical points are the set indicated as x2=x3 and x3=x4. This is one DOF. Thus the mininum for your problem isn't a point, it is a curve given by
This is, any point at this curve its a local extrema, and a minumun if t''(u)>0, which I don't check.
Best regards.
Alvaro.
Maple solution:
But I cannot get this solution in Mathcad - Mathcad 15 not answer with this task - see please the picture above
Maple-solution with units
Thanks, Fred!
But no answer on my Mathcad Prime 3.1 - see please the picture and the attach
Interesting.
3.0 will solve it but 3.1 won't!
Wonder what the difference is.
Fred Kohlhepp написал(а):
Interesting.
Fred, attach, please, your Prime 3.0 sheet!
Attached
Attached
Sorry, no solution in my Prime 3.1
No answer
I have the answer without a, b, c Prime 3.1 sheet in attach.
Found a typing error in the file.
Corrected and units added
Thanks, Fred,
but I think by numerical solution the minimize function not find is more...
Well, Fred's Prime is more powerfull.
But I insist: there are a curve as solution, not only an isolated point.
Best regards.
Alvaro.
Sorry, Alvaro!
Maple gives us a point as solution (3 roots - one real and 2 complex). See please the counter plot above too.
Or I do not understand some thing
Oh, yes, you're right. I see the plot not enough close. Solution is the intersection of this 3 surfaces:
Best regards.
Alvaro.
It is one optic problem.
Video Link : 7197
An optic solution of the problem
With plots
But no symbolical solution
