On 2/28/2009 3:31:53 PM, commendatore85 wrote:
>I need help to understand the
>problem below. The problem
>comes from the
>physicsclassroom.com site,
>static electricity. The right
>answer is provided with a
>brief explanation of the
>proceedings to solve the
>problem. Please take in to
>consideration that I don't
>have any physics teacher and
>I'm doing this as practice for
>a future course I'll take in
>college.
>I advanced smoothly until what
>I believe is the final step.
>I've got the degrees (25.6),
>force of gravity (.01176),
>electrical force (5.64 x 10 -3
>) but I just can't get the
>final answer which is
>(78.8cm). I end up either
>getting 45.92cm (by getting
>first the angle at the lower
>right corner and then getting
>the Fy value in cm, which I
>thought it was 30.75 cm and
>finally using the Pythagorean
>theorem).
>Finally I tried to use
>sin(theta) = 0.5 d / L which
>is supposed to be the solution
>to the problem, but obviously
>I'm doing something wrong
>because I end up getting like
>48.something cm. Thanks a lot
>for your time!
>3. Two 1.2-gram balloons are
>suspended from light strings
>attached to the ceiling at the
>same point. The net charge on
>the balloons is -540 nC. The
>balloons are distanced 68.2 cm
>apart when at equilibrium.
>Determine the length of the
>string.
>Answer: 78.8 cm
>Like the example problem
>above, it is best to begin
>with a sketch of the situation
>and a free-body diagram.
>Q1 and Q2 are known to be
>-5.4x10-7 C.
>The separation distance is
>0.682 m.
>Using Coulomb's law and values
>of Q1, Q2, and d, the electric
>force can be found to be
>5.64x10-3 N.
>The force of gravity is m g or
>0.0118 N.
>From the FBD and the sketch,
>one sees that the
>tangent(theta) = Felect /
>Fgrav = (5.64x10-3 N) /
>(0.0118 N) = 0.4798.
>Thus, theta (the angle with
>the vertical) is 25.6 degrees.
>From a distance triangle, one
>sees that sin(theta) = 0.5 d /
>L Substituting theta and d
>into this equation leads to
>the answer.
Looks like you need to get a new calculator:
L = 0.5*d/sin(theta) = 0.5*68.2cm/0.4322 = 78.9 cm
TTFN,
Eden
