I'm having an issue with the following and any help would be much appreciated
Lets say I have a key frequency of interest
All of the following MATHCAD code has been generated
Input Parameter:
KeyFreq=1
Output(KeyFreq)=| 0
| 10 if KeyFreq > 5
Output(KeyFreq)= 0
Now my queston is the following:
I want to find out what the Output(KeyFreq) becomes from a KeyFreq range of 1-100
I tried using the "KeyFreq=1...100", however this won't output the data.
Thanks for your assistance!
Input Parameter:
KeyFreq=1
Output(KeyFreq)=| 0
| 10 if KeyFreq > 5
Output(KeyFreq)= 0
You've probably found the solution by now, but just in case it's of any help ... see attached.
Stuart
Please upload a worksheet.
Mike
Input Parameter:
KeyFreq=1
Output(KeyFreq)=| 0
| 10 if KeyFreq > 5
Output(KeyFreq)= 0
Stuart
Thanks Stuart_Bruff,
Unfortunately I had to do the solve the problem by punching in each key frequency and seeing the output. But I do appreciate your assistance in the matter! For future analysis, is it possible to export the vector data into a table? For instance in the your attached mathcad sheet, the output was (0 0 0 0 10 10 10 10 10) for a range from 0 to 9.
Would it be possible to display the information as key frequency in a column of a table and the output in the other column as seen below
KeyFreq | Output
0 | 0
1 | 0
9 | 10
I've been tinkering with the table function in MATHcad however it's not working out as well (due to my own self admitted ignorance).
Thanks again for your assistance!
best,
Dan
KeyFreq | Output
0 | 0
1 | 0
9 | 10
The simplest way is to use augment and stack to join the data together as in the attached example. I've shown 2 choices of array result, matrix and table. Double click on an array result to bring up the 'Result Format' dialog and choose whichever option you prefer from the 'Display Options' tab. If you choose table format, the right-clicking on the table and choosing 'Properties' will allow you to choose the font and whether or not to display the row/col labels.
best,
Dan
No worrries,
Stuart
