Simplify
Raj_mathcad
Simplify
I am not able get the desired output for a simple calculation with simplify keyword.
Please refer the below screen shot
Any suggestions?
- Raj
RichardJ
(To:Raj_mathcad)
The symbolic processor does not make many of the assumptions you do. You may well not even be aware that you are making such assumptions; it's a common mistake. In general, sqrt(x^2) is not equal to x. It is equal to x only if you restrict the domain of x to positive real numbers. If you want to restrict the domain of some or all of the variables then you usually have to explicitly tell the symbolic processor to do so.
Richard
Oh! yes. I am missing some Mathcad basics here..
Thanks Richard..
-Raj
___________________________
jmG
