Dear All,
I would like to receive clarifications about the solution of a nonlinear system through the use of a solve block Given/Find. In the attachment it is reported the system that make use of the symbolic derivative operators ( EOS isothermal inflection point- critical conditions ) . The solution converges only up to a certain value of the input parameter ( epsaa, Vaa ). Any suggestion how to solve this issue?
Your sincerely,
Massimiliano
You're trying to solve the system for T=Tc. See what that does to the value of the Covolume Soft-core parameter:
You may get a division by zero.
Further:
I tried to solve the set symbolically (with part of the parameters defined)
and after 30 minutes it found no answer.
Hope this helps.
Hello Luc,
The system has three unknowns ( εc,η and bc ) in three equations. As shown in attachment, the Solve Block is solved only up to a certain value of εaa and Vaa ( EOS parameters ).
The equation you considered added a further variable : b.
