I am trying to solve a symbolic inequality with multiple variables. I can't seem to get a solution in general when I have explicit constants in the constraint that contain decimal points. How do I go about solving such problems?
Is there a particular reason why you have to include the explicit constraints in the inequality?
Stuart
Stuart
Thanks Stuart. I re-arranged my problem to be purely symbolic, but it now requires a lot of calculation time. I've attached my problem in context. Is approach #2 in the attached Mathcad sheet correct?
