Symbolics with vectorize & scalar product
Liv
Hello everyone !
It seems to me that symbolic calculation works strangely when applied to scalar product of two vectors, even if I use vectorize operator.
The consequent error message "Divide by 0" is then not so unexpected... Or maybe it's me who's wrong there.
What's the meaning of the bar above T in one of the symbolic results ? (attached worksheet).
Many thanks, Liv.
24-Ruby V
(To:Liv)
Yes, symbolic evaluation will not use automatic implicit vectorization, whereas numeric evaluation will do.
You have to explicitly vectorize when using symbolic eval (and I would advise to do so with numeric eval as well).
In this case the problem is the exponentiation of the vector, which is not a valid operation on vectors from a mathematical point of view and so muPad refuses to simplify it. In the multiplication the expression is treated like an unknown scalar and thats the reason we get a vector result.
The numerics of Mathcad applies automatic implicit vectorization if an operation is not defined for vectors and does what you probably expected - creating a new vector which then is multiplied by the second vector..
To achieve the same effect using the symbolics, you have to explicitly vectorize that part of the expression.
Example:
10 REPLIES 10
(To:Liv)
It's because x is undefined. The symbolic solver doesn't mind, simply puts x in the answer.
You use the vectorize operator, so with a vector as input, you should expect a vector as result.
I don't see "the bar above T in one of the symbolic results".
Liv
(To:LucMeekes)
Obviously, you are right there and me definitely wrong
24-Ruby V
(To:Liv)
It works, if you vectorize the whole expression (including the division)
This means the conjugate complex of T.
It has to do with the mathematical definition of the scalar product:
You can avoid it by using the appropriate matrix multiplication (transpose the first factor to do so)
or tell Mathcad/MuPad that you don't use non-real numbers
But I am not sure which calculation you had in mind and if that partial vectorization was done on purpose:
Liv
I think I messed my comments in posted worksheet...
The desired result for Lambda1f is a scalar (a single function of x and T), same as for Lambda2f and Lambda3f. That is a scalar (one function) at both numerator and denominator of Lamda1f.
But you are right, Werner, there is assume/real in Symbolic of Mathcad in order to make use of.
Liv
(To:Liv)
Ok, there's M^1/3 too  ,    which seems to behave differently in numeric and symbolic calculation...
24-Ruby V
(To:Liv)
Example:
Mathcad 11:
The error messages are in all 4 cases: "No symbolic result was found.", which is a viable statement considering the mathematical incorrectness. But it's sad that the vectorization does not seem to get transferred to the symbolic domain.
Mathcad11/Maple also refuses other exponents (I tried '2').
I guessed that Maple would react differently and I agree that its sad that vectorization does not work as it should with symbolic eval.
Think that has nothing to do with Maple but its a matter of Mathcads interface to the symbolics which obviously was improved somewhere on the way to MC15.
Just see that I inserted a wrong picture when I was talking about he matrix product.
It should have been this one
Liv
Problem solved.
Thank you both, Luc and Werner, for considering it.
