Hello
What is the difference between Prime and Machcad 15, because the function works in 15, but in Prime does not work.
And also there is a possibility that Pime read M 15.!
greetings
It works when I try it in Prime 3.0:
What's the error message?
Prime can convert Mathcad 15 files, but not read them. See the input/output tab. You need to have Mathcad 15 installed, and the converted worksheet may not work, and may need editing.
bens djel написал(а):
Hello
greetings
You must use the convertor in Prime to convert xmcd into mcdx format.
Looks like you used a literal subscript (Ctl+-) where you should have used a matrix index ([) for fi.
Note the difference between the two in the following example:
The literal subscript returns the error shown.
Visually, the matrix index is lower than the literal subscript.
thanks a lot for your help
