What is the difference between Prime and Machcad 15
bdjel
  Hello
What is the difference between Prime and Machcad 15, because the function works in 15, but in Prime does not work.
And also there is a possibility that Pime read M 15.!
greetings
RichardJ
(To:bdjel)
It works when I try it in Prime 3.0:
What's the error message?
Prime can convert Mathcad 15 files, but not read them. See the input/output tab. You need to have Mathcad 15 installed, and the converted worksheet may not work, and may need editing.
bens djel написал(а):
  Hello
greetings
You must use the convertor in Prime to convert xmcd into mcdx format.
RichardJ
(To:bdjel)
MJG
18-Opal
18-Opal
(To:bdjel)
Looks like you used a literal subscript (Ctl+-) where you should have used a matrix index ([) for fi.
Note the difference between the two in the following example:
The literal subscript returns the error shown.
Visually, the matrix index is lower than the literal subscript.
bdjel
(To:MJG)
thanks a lot for your help
