Hi all,
I am still new to mathcad, can you please help me with the following question?!
I am trying to solve the attached equation in mathcad for t(i), and plot t(i) vs Mcor(i)/Mco(i). But I can't make mathcad to solve t for me,
I appreciate very much your answers!
Are you sure about the equation? Its not dependent on the ratio of the two M's but on their product.
Anyway, leave away the i - you have not defined a range i anyway.
Use the boolean = in your equation (no i's), put in into a solve block between Given and Find(t). Put a guess value in front of the Given and turn the solve block into a function of MCor and Mcor --> f(Mcor,Mco):=Find(t)
After that you may define your vectors Mcor and Mco and call f(Mcor,Mco), but you have to vectorize that call because of you vector arguments.
I found that the results are very dependent on the guess value and may range up to t=10^44 with the equation given.
