Hi
How do you calculate number of turn in a coil
An inductor core of reluctance 5.2 MA/Wb, cross-sectional area 245 mm2 and length 454 mm is evenly wound with a coil. When a current of 0.5 A flows in the coil, a magnetic flux density of 0.127 T is set up in the core.
Calculate the number of turns in the coil.
thanks
Can you write the equations?
We won't do your homework for you; we will help you sort out problems.
Hi
I am struggling to find an formula given the parameters, not asking you to solve the problem Any suggestion?
If you are asked this as a homework question, then you must have been given the formula for the magnetic field generated by a coil.
An Introduction to Electronic Design, Bock, Ditmar, 2nd Ed, Boston Research, Colden NY, 1982.
You need to show that you have made some attempt to solve this by yourself. If you have a specific problem we will point you in the right direction, but as Fred says, we will not do your homework for you.
