can i get the value of a specific letter from a equation?
ptc-4982277
i better do math than talk in english.
D:=42
L:=41
C:=5
C:=(D-d)/L
can i get the value of "d"?
(yes, can be done even mentally, but how you do it in mathcad?)
Try the following:
It is helpful to know which version of Mathcad you are using.
If you want to solve to "d" then look at using symbolic math (in help). The := or definition operator should not be used here but use the evaluation operator (displayed as a bold =). Then you can solve for "d". Again, looking at symbolic examples in help should help you along...
I hope this helps.
(To:ptc-4982277)
Or you could do it purely numerically, by using the root function with C-(D-d)/L as the first argument.
Try the following:
the most helpful one, thanks a lot!
You're welcome.
